jjang's avatar
jjang
4 years ago
how to capture data to file
Target Device : Max10 (10M50SAE144I7N) Sampling Clock : 40Mhz Required period : 5ms or over i tried ram size maximum 128k @ 3ms under so is there any way how to capture data over 1ms
  • sstrell's avatar
    4 years ago
    No. To capture more data in the existing buffer, use data qualification to store only the relevant samples. For example, if signals don't transition for a number of clock cycles, there's no need to keep all of those data samples. Use data qualification as essentially a write enable to the buffer.
