tpalomaki
4 years agoHLS i++ compile failure for Quartus Prime 21.1.1 Lite
in the HLS examples in folder: hls\examples\counter
command line: "build test-fpga"
command output:"
i++ -march=CycloneV counter.cpp -o test-fpga.exe HLS Testbench parse FAILED. Run test-fpga...
tpalomaki
4 years agoAn additional bug to report (quartus prime lite 21.1.1 recent version).
When you create new project, then go into the folder selection, the whole program crashes, but when you directly type the path into the path box, then it will work and make the new project, pressing the path directory location button will crash after it has opened and shown the location almost immediately.
Hope this helps you to track down this problem.
