tpalomaki
4 years agoHLS i++ compile failure for Quartus Prime 21.1.1 Lite
in the HLS examples in folder: hls\examples\counter
command line: "build test-fpga"
command output:"
i++ -march=CycloneV counter.cpp -o test-fpga.exe HLS Testbench parse FAILED. Run test-fpga...
BoonBengT_Altera
Moderator
4 years agoHi @tpalomaki,
Apologies for the inconvenient cause, it would be a great help if you are able to provide us with a screenshot of the output when running the init_hls.bat for further troubleshooting.
And what would be the build version that your Window 11 are having? Im in the mids of contacting the platform team to confirm on the supportability.
Looking forward hearing from you.
Best Wishes
BB
tpalomaki
4 years agoseems like the error points to different direction than the compiler was instructed to look in, the "host" directory is missing in the error.
