The datasheet LVDS TX Datarate shows that it cannot go up to 1Gbps.
When you say: This has proven to be reliable and working well during development using single ended TTL outputs...do you mean you are able to implement this in actual board at 1Gbps datarate?
Yes and no:
Implement reliably on a board: Yes, on the Intel EK-10CL025U256
1Gbps data rate: Yes & No: The edge position resolution is 1ns (thus information is transmitted technically with 1Gbps), however the pin can only toggle with at most 62.5MHz as it is impossible for the coounter to reset in less than 16 cycles with the output going high at least once per period.
It is possible to toggle the pin high or for a single cycle, which results in a well defined output signal with a clean signal, that is eighter high or low for only 1ns, but not both, the period is at least 16 cycles.
In essence, the transition edges are positioned using 1GHz clock, the square signal however toggles with max. 62.5Mhz. Should glitches occur when the on/off times are lower than 2ns, this is perfectly acceptable since all the driven external circuitry would recognize this as noise and ignore it entirely anyway.
Edit: During development i managed to test also toggle rates on TTL pins that were according to the design limits not capable of toggle rates of over 500MHz (and in case quartus detected it based on the logic used to drive the pin, rejected with a similar error; For that experiment i could afford extra locic, so i used secondary inputs that i then tied to VCC to trick quartus into thinking the pin would not toggle at that rate - this is no longer an option as the final implementation does not allow for any extra delays before the output.) at up to 1.3GHz and the output signal was still well enough defined for what we need. This may well be a reliability topic and may cause other potentially unexpected behaviour, however it it would be nice to at least be possible to bypass the error, as the device is clearly capable of operating in those conditions.
- JonWay_altera5 years ago
Hi Chris,
Could you attach a simplified design that shows the error?
- chris_notsch5 years ago
Yes, give me a few hours. I am working on a test program for this issue at the moment. I will attempt to modify it so it reflects the real application as close as possible.
@JonWay_C_Intel I have created and attached two configurations of a example project configured to run on the Intel Cyclone 10 LP Evaluation Kit.
one configuration showing the error message, and one showing that the settings rejected by quartus are valid (using on the fly reconfiguration to allow compliation with lower clock speed).
The example contains a description on how it is constructed and how to connect it as well as the resulting output waveforms.
Materials required:
EK-10CL025U256
Oscilloscope with >= 1Ghz bandwith & differential probe, 100 Ohm LVDS termination resistor, + 1 Single ended probe
Quartus Prime 20.1.0 Build 771 06/05/2020 SJ Lite Edition
Thank you for your support,
Chris
Thanks for the design. I have a better idea now. You are trying to make a GPIO IO standard LVDS to toggle at 1GHz. It will message: Error (176060): The transmitter driving I/O pin pin_arduinobus_j7_4 at data rate 1000 Mbps exceeds the maximum allowed data rate of 740 Mbps for LVDS output
This is expected as the datasheet stated:
