Understood. Some configuration pins can be used as I/O after configuration and for some reason the tool is not seeing that here even though AE5 is not even being used in that way. I was just saying that Y4 (that you mentioned originally) and AE5 are both "DATA0" but for different configuration schemes.
I guess I would try creating a brand new project first just to rule out any settings or database corruption. After that, yes, it could be a bug.
Hello, sstrell-san.
Your message gave me a hint.
When I looked at the Dual-Purpose Pins setting, I saw that Data[0] was in Dual-Purpose Pins.
This is my first time using the Cyclone 10GX, and in the Flex10K and other Cyclone families that I have used up until now, AS_Data0 and Data[0] were assigned to the same pin, so I assumed they were the same.
When I set DATA[0] to "Use as regular I/O", I was able to compile without errors.
By the way, this is the board we will be using this time.
https://www.hdl.co.jp/ACM-115L/
This board was first released in March 2019, but it seems that the Enpirion power supply IC was discontinued and replaced with a new one, resulting in the current version.
Thanks, hidetaka.
- sstrell10 months ago
Awesome! I forgot about the dual purpose pins setting.- Hidetaka10 months ago
Hello, sstrell-san.
This has been resolved for now, so you may close this case.
Personally, I thought it would be better if Quartus would automatically set Data[0] to "Use as regular I/O" when I selected Active Serial in the Configuration scheme.Thanks, Hidetaka.
I'm not a moderator, but yes, that would make sense to avoid a silly, difficult to diagnose issue like this.
