File Location of "fpga_designer.zip"
Hi @rt11
The issue has been fixed and you should be able to find it in the class resources.
Richard Tan
Richard Tan,
Thank you for uploading the files, I was able to proceed with the course.
Note the "fpga_designer.zip" that was uploaded as the download resource for the class is an older version (I think it was v14.0 dated around 2014 ....this is from memory) for the course. There are two Lab manual (pdf) which are separate download also provided as a resource for the class however these are version 17.0 dated 2017. If one uses the v 17.0 lab manual with the provided files in "fpga_designer.zip" will find these are two different versions of the course and and are not compatible with each other (files are missing, named differently, and different/additional steps are needed).
The "fpga_designer.zip" had a Lab manual (pdf) included, which I eventually followed, and went with the files provided in the zip.
These file mismatches will cause confusion with future students.
Also took the following course:
Creating a System Design with Platform Designer: Getting Started
Creating a System Deisgn with Platform Designer: Finish the System
This course did not have the lab manual and resource files either.
Thank you,
RT
- sstrell4 years ago
The Platform Designer course missing resource links are being fixed.
