Error When Creating Project in Platform Designer in Quartus Prime Pro 19.3
- 5 years ago
Hi @rewingchow
Since you mentioned that Quartus 20.1 and onwards are fine, I would recommend that you upgrade your project to the latest Quartus version 21.2 to check if the issue still persist.
We have fixed a lot of bugs with the latest Quartus version.
Richard Tan
Can you successfully create a project in Quartus and then create a system design in PD and associate it with the project's .qsf file?
That flow does the same thing as what you are attempting. I don't know why it error out like this.
I can do that, it only does not work when creating through Platform Designer. I need this method to work as it allows for my tcl script to work.
- sstrell5 years ago
Why are you referencing 18.0 as the version at the top of your script? Maybe that's the issue.
