Hi Sheng,
You cannot change s_outbytecount to 0 only in line 151, you have to change s_outbytecount in line 150 to 0 as well, because line 151 is constrained by line 150.. By changing value of s_outbytecount to 0 only in line 151, you are making logical error and regardless of compiler this would lead to an error.
Please do not play with s_outbytecount in line 151. You can notice that s_outbytecount is calculated in line 146 and 153.
If you want to change s_outbytecount to see line 151 behavior, you have to calculate (d - s_outbytecount) value in line 151.
W_MODULE_DATA = 16,
c_OUT_DATA_BYTE_CNT = 32,
c_IN_DATA_BYTE_CNT = 2 and
Line 148 to152:
148: for (int d = 0; d < c_OUT_DATA_BYTE_CNT; d++)
149: begin
150: if ((d >= s_outbytecount) && (d < (s_outbytecount + c_IN_DATA_BYTE_CNT)))
151: s_output_data[d] <= s_in_data[((W_MODULE_DATA - ((d - s_outbytecount) * 8))- 1) -: 8];
152: end
In line 148 d can take 0 to 31
In line 151 d is constrained to be from s_outbytecount to (s_outbytecount + c_IN_DATA_BYTE_CNT) - 1
Since W_MODULE_DATA = 16, ((d - s_outbytecount) * 8)) can take only 0 or 8.
when ((d - s_outbytecount) * 8)) = 0, ((W_MODULE_DATA - ((d - s_outbytecount) * 8))- 1) = 15
when ((d - s_outbytecount) * 8)) = 8, ((W_MODULE_DATA - ((d - s_outbytecount) * 8))- 1) = 7
So line 151 would not have any errors
In other words, ((d - s_outbytecount) * 8)) cannot be greater than 8 or less than 0.
Please concentrate only on line 142, 143 (these if statements are bound by for loop in line 140)
and 151(this if statement is bound by for loop in line 150).
Ranesh
Hi Sheng,
There was a mistake in last line of my last reply:
The lie
"Please concentrate only on line 142, 143 (these if statements are bound by for loop in line 140)
and 151(this if statement is bound by for loop in line 150)."
is not correct. It should be
"Please concentrate only on line 142, 143 (these if statements are bound by for loop in line 140 and 145)
and 150 (this if statement is bound by for loop in line 148 and 152)."
Thank you.
Ranesh
