RBF Conversion for S10
I'm running a conversion to create the rbf for the S10 dev board:
quartus_pfg -c Test_S10Dev.sof ghrd.jic -o device=MT25QU02G -o flash_loader=1SX280HU2F50E1VGAS -o hps_path=u-boot-spl-dtb.hex -o mode=ASX4 -o hps=1
I compiled the sof using Quartus 24.1. When I run the conversion using quartus_pfg from the 24.1 bin folder and put the generated rbf on the SD card to I get an error during boot:
Error sending bitstream! Command 'load' failed: Error -110
When I run the same conversion command but using the quartus_pfg in my 23.1 bin folder and use that rbf file on the SD card then it loads the S10 with no issues.
The hex file I'm using is from: https://releases.rocketboards.org/2021.04/gsrd/s10_gsrd/u-boot-spl-dtb.hex
Output from both conversion are attached.
Anything I need to be doing different on 24.1 to make this work?
- EBERLAZARE_I_Intel
Is this ticket a duplicate ticket you filed previously? If yes, can we work on one ticket on the issue? I shall close the duplicated ticket.
- GMcCa2
Yes, when I created the other one it was marked as spam, which seems to happen when I include error logs in the message. I recreate it with the logs as attachments and it did not mark it as spam.
Got it, we will track and support this ticket in the other forum ticket that you filed.
I will close this ticket.
