Altera_ForumHonored Contributor16 years agoramstyle attribute in Quartus synthesis I am trying to create some verilog that will receive a message with a set of sample data from a Nios processor and send the samples out on digital i/o pins sequentially. The message size is 512 bytes...Show More
Altera_ForumHonored Contributor16 years agoHi, Thanks! Seems I have indeed advertized my ignorance!:o Regards, Niki
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
