16 years agoHi Niki,
--- Quote Start --- Hi, Not knowing Verilog, something did strike me as odd in your code. Your always process is defined as: always @ (posedge clk or negedge reset_n) It seems like you want the process to trigger on a rising clock edge or a falling reset_n edge. Normally you want the process to trigger on the clock edge and on the reset level. Having two edges like this is generally not synthesizable - or at least not to the logic you intended. I may just be advertising my ignorence, and maybe this is the way you specify it in Verilog, it just lokked odd to me. --- Quote End ---always @ (posedge clk or negedge reset_n)is perfectly OK to design synchronous circuits with asynchronous reset.
