16 years ago --- Quote Start --- Not knowing Verilog --- Quote End --- That's excadtly the point. Although always @ (posedge clk or negedge reset_n) may look strange to a VHDL programmer, it's correct synthesizable Verilog syntax. It's simply the equivalent of the VHDL construct --- Quote Start --- if reset_n ='0' elsif rising_edge(clk) end if; --- Quote End --- You may want to take a look a the Quartus Verilog templates to get an idea of it, The "ignoring ramstyle" problem is rather obvious from this lines
samples_to_send <= {act_message, act_message, act_message, act_message};
clocks_per_sample <= 50*({act_message, act_message, act_message, act_message}); They would already require an 8-port RAM, because 8 values are read simultaneuosly.
