16 years agoHi,
Unfortunately I do not know Verilog well, but the more typical way of using a RAM would be to instantiate a RAM component. You can do this with the Plug-In Megawizard, or by hand if you know the model name and parameters. There has been a post some time ago about the ability of Quartus to recognise a RAM from behavoural code and then to automatically instantiate a RAM component, but that was for VHDL. Your syntax needs to be correct for the compiler to recognise the RAM. Personally I prefer to instantiate the RAM component explicitly since then I have control over the use of my RAM resources. Regards, Niki
