10 years ago
RAM write and read
I little bit confused with dual port RAM,my target is write and read data.I want to write data.like on the certain positions will be 128 and on the rest positions will be just 0.
I reading this article https://www.altera.co.jp/ja_jp/pdfs/...s_qii51007.pdf (https://www.altera.co.jp/ja_jp/pdfs/literature/hb/qts/qts_qii51007.pdf)
and I think I need true dual port Ram.
 library ieee;
    use ieee.std_logic_1164.all;
    entity true_dual_port_ram_single_clock is
generic (
      DATA_WIDTH : natural := 8;
      ADDR_WIDTH : natural := 6     );
     port (      clk : in std_logic;
addr_a : in natural range 0 to 2**ADDR_WIDTH - 1;
addr_b : in natural range 0 to 2**ADDR_WIDTH - 1;
data_a : in std_logic_vector((DATA_WIDTH-1) downto 0);
data_b : in std_logic_vector((DATA_WIDTH-1) downto 0);
we_a : in std_logic := '1';
      we_b : in std_logic := '1';
q_a : out std_logic_vector((DATA_WIDTH -1) downto 0);
q_b : out std_logic_vector((DATA_WIDTH -1) downto 0)
end true_dual_port_ram_single_clock;
    architecture rtl of true_dual_port_ram_single_clock is
-- Build a 2-D array type for the RAM
subtype word_t is std_logic_vector((DATA_WIDTH-1) downto 0);
type memory_t is array((2**ADDR_WIDTH - 1) downto 0) of word_t;     -- Declare the RAM signal
     shared variable ram : memory_t;
begin     process(clk)     begin     if(rising_edge(clk)) then -- Port A
      if(we_a = '1') then
         case addr_a is
        when 0 =>
        data_a <= 128;
        when 16 =>
        data_a <= 128;
        when others =>
        data_a <=0;
        end case;
       ram(addr_a) <= data_a;
       -- Read-during-write on the same port returns NEW data
       q_a <= data_a;      else
       -- Read-during-write on the mixed port returns OLD data
       q_a <= ram(addr_a);      end if;
     end if;     end process;
     process(clk)
 begin
if(rising_edge(clk)) then -- Port B
      if(we_b = '1') then
 ram(addr_b) := data_b;
 q_b <= data_b;
      else
q_b <= ram(addr_b);
      end if;
   end if;
end process;
     end rtl;
Could you pls give any guidance for my code?
    why even bother with a ram if all you are doing is translating the address? why not just a LUT or even just input decoder?
    could you pls give an example in this case?With LUT or decoder?
    --- Quote Start ---
    --- Quote End ---
