9 years agoRAM property help
Hi all, I have a question about using on chip ram. According to what I read from the quartus handbook, the port input (e.g. address, input data) to a RAM should be clocked in order to let softw...
9 years agoIn the fitter report tyre is a section that lists resource usage by entity. You can use this to find it which block is using lutram rather than dedicated rams. But i suspect you have run out of ram is they are all generated from the mega Wizard.
