9 years agoRAM property help
Hi all, I have a question about using on chip ram. According to what I read from the quartus handbook, the port input (e.g. address, input data) to a RAM should be clocked in order to let softw...
9 years agohi,
I use the wizard to generate most of the ram and port map to it. the only ram i did not directly use wizard is the one with mif file. There are 64 of them with different mif file. But I just copy the code and edit the mif file name only.
LIBRARY ieee;
USE ieee.std_logic_1164.all;
LIBRARY altera_mf;
USE altera_mf.altera_mf_components.all;
ENTITY mem_0 IS
PORT
address_a : IN STD_LOGIC_VECTOR (6 DOWNTO 0);
address_b : IN STD_LOGIC_VECTOR (6 DOWNTO 0);
clock : IN STD_LOGIC := '0';
data_a : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
data_b : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
rden_a : IN STD_LOGIC := '1';
rden_b : IN STD_LOGIC := '1';
wren_a : IN STD_LOGIC := '0';
wren_b : IN STD_LOGIC := '0';
q_a : OUT STD_LOGIC_VECTOR (31 DOWNTO 0)
END mem_0;
ARCHITECTURE SYN OF mem_0 IS
SIGNAL sub_wire0 : STD_LOGIC_VECTOR (31 DOWNTO 0);
SIGNAL sub_wire1 : STD_LOGIC_VECTOR (31 DOWNTO 0);
BEGIN
q_a <= sub_wire0(31 DOWNTO 0);
q_b <= sub_wire0(31 DOWNTO 0);
altsyncram_component : altsyncram
GENERIC MAP (
address_reg_b => "CLOCK0",
clock_enable_input_a => "BYPASS",
clock_enable_input_b => "BYPASS",
clock_enable_output_a => "BYPASS",
clock_enable_output_b => "BYPASS",
indata_reg_b => "CLOCK0",
init_file => "router_0_init_data.mif", ----------- I only edit this line for diff mif file name
intended_device_family => "Stratix V",
lpm_type => "altsyncram",
numwords_a => 128,
numwords_b => 128,
operation_mode => "BIDIR_DUAL_PORT",
outdata_aclr_a => "NONE",
outdata_aclr_b => "NONE",
outdata_reg_a => "CLOCK0",
outdata_reg_b => "CLOCK0",
power_up_uninitialized => "FALSE",
ram_block_type => "M20K",
read_during_write_mode_mixed_ports => "DONT_CARE",
read_during_write_mode_port_a => "NEW_DATA_NO_NBE_READ",
read_during_write_mode_port_b => "NEW_DATA_NO_NBE_READ",
widthad_a => 7,
widthad_b => 7,
width_a => 32,
width_b => 32,
width_byteena_a => 1,
width_byteena_b => 1,
wrcontrol_wraddress_reg_b => "CLOCK0"
PORT MAP (
address_a => address_a,
address_b => address_b,
clock0 => clock,
data_a => data_a,
data_b => data_b,
rden_a => rden_a,
rden_b => rden_b,
wren_a => wren_a,
wren_b => wren_b,
q_a => sub_wire0,
q_b => sub_wire1
END SYN;
The above is what I have for the ram with .mif file. Then I use matlab to print these code 64 time with different mif file name. Is there anything wrong with it? Currently I am not sure which memory is fitted to logic cell, but other rams I have is directly port map to the wizard generated component, thus I think the above one might be the one using logic cell. Is there any way I can check which ram is generated by logic cell? Does Quartus have this function? many thanks for the help.
