9 years agoRAM property help
Hi all, I have a question about using on chip ram. According to what I read from the quartus handbook, the port input (e.g. address, input data) to a RAM should be clocked in order to let softw...
9 years agoYou didn't show the ram code. If you are having problems inferring ram, you may be better off generating the ram from the megawizard/ip catalogue to ensure you alwaus get the ram you want.
Without seeing the ram code, is impossible to say what's wrong with your code.
