17 years ago
radix different nodes in Verilog with quartus
hi guys,
i am trying to write a code to implement a pwm using verilog on quartus, and wired stuff comes up.
here is the code i had,i have 2 pwm outputs. the idea is to have a counter counts up to 2^20, and a reference "ref" to be a output from the microprocessor from SOPC and then to be compared with the clock in the "pwm" module , if the counter is greater then this reference, the output will go high,else low
this is my top module
module myservo(
//inputs
CLOCK_50,
reset_n,
//outputs
GPIO_01, //pwmoutput
GPIO_02, //pwmoutput
//sram
SRAM_CE_N,
SRAM_OE_N,
SRAM_ADDR,
SRAM_UB_N,
SRAM_LB_N,
SRAM_DQ,
SRAM_WE_N
//input and outputs
//system
input CLOCK_50,reset_n;
//sram
output SRAM_CE_N;
output SRAM_OE_N;
output[17:0] SRAM_ADDR;
output SRAM_UB_N;
output SRAM_LB_N;
inout [15:0] SRAM_DQ;
output SRAM_WE_N;
//SRAM variables
wire SRAM_CE_N;
wire SRAM_OE_N;
wire[17:0] SRAM_ADDR;
wire SRAM_UB_N;
wire SRAM_LB_N;
wire[15:0] SRAM_DQ;
wire SRAM_WE_N;
output GPIO_01,GPIO_02;
wire[19:0] PWMSERVOL_PIO;
wire[19:0] PWMSERVOR_PIO;
// instantiate NIOS processor
myup processor_instance(
.chip_select_to_the_static_ram_0 (SRAM_CE_N),
.clk_0 (CLOCK_50),
.out_port_from_the_PWMSERVOL_PIO (PWMSERVOL_PIO),
.out_port_from_the_PWMSERVOR_PIO (PWMSERVOR_PIO),
.read_n_to_the_static_ram_0 (SRAM_OE_N),
.reset_n (reset_n),
.tri_state_bridge_0_address (SRAM_ADDR),
.tri_state_bridge_0_byteenablen ({SRAM_UB_N,SRAM_LB_N}),
.tri_state_bridge_0_data (SRAM_DQ),
.write_n_to_the_static_ram_0 (SRAM_WE_N)
pwm servopwm_instance(
//module pwm inputs
.clk_pwm (CLOCK_50),
.reset_pwm (reset_n),
.refL (PWMSERVOL_PIO),
.refR (PWMSERVOR_PIO),
//module pwm outputs
.pwmoutservoL (GPIO_01),
.pwmoutservoR (GPIO_02)
endmodule
this is my pwm module
module pwm(
//module pwm inputs
clk_pwm,
reset_pwm,
refL, //reference for the comparator
refR, //reference for the comparator
pwmoutservoL,
pwmoutservoR
//pwmservo ports declearation
input reset_pwm;
input clk_pwm;
input [19:0] refL;
input [19:0] refR;
output reg pwmoutservoL;
output reg pwmoutservoR;
wire [19:0] count1;
always@(posedge clk_pwm)
begin
if(count1>refL)
begin
pwmoutservoL<=1;
end
else
begin
pwmoutservoL<=0;
end
end
begin
if (count1>refR)
begin
pwmoutservoR<=1;
end
else
begin
pwmoutservoR<=0;
end
end
count c1
.clk_count (clk_pwm),
.reset_count (reset_pwm),
.countout (count1)
endmodule
this is the count module
module count(clk_count,reset_count,countout);
input clk_count,reset_count;
output reg [19:0]countout;
always@(posedge clk_count or posedge reset_count)
begin
if(reset_count)
begin
countout<=0;
end
else
begin
countout<=countout+1;
end
end
endmodule
the pwm module works fine on its own in simulation when the ref is changed to a input port of the pwm module which is the top module in the simulation.
file:///C:/Users/FRANKI%7E1/AppData/Local/Temp/moz-screenshot.jpg
but with the whole thing there is just no output at all.
i am writing to the PWMSERVOL_PIO which is the "ref" connectted with "wire" by nios .
just through
IOWR_ALTERA_AVALON_PIO_DATA(PWMSERVOL_PIO,900000)
i tried to add a ouput from the microprocessor by sopc and i can get a output from the output pin which is only one bit. the "ref" and the PIO ports are 20 bits wide and i am assuming everything include the clock is in decimal, but maybe not
i am thinking it was because all the ports didn't have the same radix, and if there is a way to modified all ports are the same radix? totally no idea.
or the way i connect the PIO ouput to the "ref" in my lower pwm module?
i am using a DE1 board by the way
well
it's quite long so thanks for reading and giving advice.
