ZhaoyangDu
3 years agoR-tile Avalon® Streaming Intel® FPGA IP for PCI Express* Design Example, VCS simulation failed.
I can't get the original R-tile Avalon® Streaming Intel® FPGA IP for PCI Express* Design Example's VCS simulaiton passed. The error is compilation error : "[PE_CDB] corrupted data block" shown in th...
Wincent_Altera
3 years agoHi,
Can you run the command provided in below KDB and see if the same error still able to obtain ?
Wincent_Intel
- ZhaoyangDu3 years ago
I have used exactly the same command as in the link you provided and encountered the same error in this post.
Zhaoyang Du
I used exactly the same cmd as in the link when I encountered the errors in this post.
sh vcs_setup.sh USER_DEFINED_COMPILE_OPTIONS="" USER_DEFINED_ELAB_OPTIONS="-xlrm\ uniq_prior_final\ -debug_access+all" USER_DEFINED_SIM_OPTIONS="" TOP_LEVEL_NAME="pcie_ed_tb" | tee simulation.log
Zhaoyang Du
