13 years ago
question regarding random number generator
hii..
i would like to ask if there is any library that have a function to generate numbers randomly within certain range..???
i wanna make a component that takes an input once add to its value 15 and subtract from it 15 and gives output within this range randomly
i.e --> output= rand[input+15, input-15]
i've no problem with the design except of the part of random value generation
i did some work arround to do so that i'm not satisfied with..
here is what i did --> xoring 2 bits putting the result in another place..
any idea how can i do this..
all your helps highly appreciated..
thanks,
Niveen..
  • josila's avatar
    josila
    An LFSR is a good option for generating pseudorandom values in FPGA designs. You can also test sample outputs with this random number tool: https://gerador-br.com
    --- Quote Start ---
    whenever i try to post any "reply with quote" it dissapear once i click "post".. any idea why does this happen
    --- Quote End ---
    Works fine for me - WinXP + Firefox.
    Cheers,
    Dave
    Thanks alot Dave for the tutorial.. :)
    thanks,
    Niveen..
    --- Quote Start ---
    Questions:
    1. Should this block be synthesisable?
    --- Quote End ---
    no just testing
    --- Quote Start ---
    Questions:
    2. How "random" does it need to be?
    --- Quote End ---
    i want to generate 36 output values with only 1 input
    --- Quote Start ---
    Questions:
    I ask these questions because:
    1. VHDL has a random number generator, but it is not synthesisable and only meant for testbenches
    --- Quote End ---
    would plz tell me about it, and if it take range or not??
    --- Quote Start ---
    Questions:
    2. Have you looked into a LFSR? http://en.wikipedia.org/wiki/lfs with this you can create a pseudo random sequence. This would be the easiest logic solution. I have heard of others before but they often involve rlocs and require good knowledge on oscilators. One solution (i havent done it, but had it described) is to route a clock though some logic as far apart as possible. Then sample the clock at a given rate, to try and give a random bit (it was described to me a long time ago, so I may have some details wrong).
    --- Quote End ---
    the work arround i did was similar to LFSR..
    execuse me, i couldn't get the rest of this..
    thanks,
    Niveen
    Questions:
