dj-park
3 years agoQuestion on AN899 (Reducing Compile Time with Fast Preservation)
My understanding is that Fast Preservation option is for when you want to import the "static" design, but the tool unnecessarily spends time with compiling the static design.
1) In this page of ...
- 3 years ago
Like I said, if you're not specifically creating a PR design, then you would want to use the Reserved Core option just like the tutorial says. Setting it to Reconfigurable enables additional device features and logic to allow for a runtime partial reconfiguration, which is not necessary. Fast Preservation can be used for either a PR or non-PR design. This training sums it all up pretty well: https://cdrdv2.intel.com/v1/dl/getContent/652891
dj-park
3 years agoThanks for the answer.
1) Based on what you said, there should be no problem using Fast Preservation option even if the tutorial is with Reserved Core option. Is this correct?
2) Resolved.
