12 years ago
Question about Modelsim user defined radix
In Modelsim wave view window, is it possible to set the radix for separate bit(s) in the signal. For example:
0000000010101100 (binary radix), instead of showing '172' in decimal radix, I'd like to see the decimal radix for each byte, namely {0,172}?
1 Reply
    you can separate out and group each byte yourself, and then show each byte as decimal. This might be the easiest. The only way I know to define custom radix is define each state separately, which in your case is 2^16, which would mean way to much to code.
