11 years ago --- Quote Start --- I know, that it would be better to use HDL. Before Quartus, i worked a lot with simulink, so the schematic entry is the thing i want to start in quartus. --- Quote End --- Ok, I just wanted to provide you some advice. Its ok for you to ignore it :) --- Quote Start --- Now, i created a prbs block. Works as it should so far. Thank you for your support! --- Quote End --- Great! You're welcome. Cheers, Dave
