9 years agoQuestion about 1 port ram
Hello, I am new to VHDL. Currently I need to use M20K memory on Stratix V chip to store some data. I have two of these kind memory, m1 and m2. Each have 128 data, each data is 32 bit. I also use comp...
9 years ago --- Quote Start --- 128 data at 32 bit is only 4k, using only about 20% of the ram. What architecture are you talking about. Do you have some code we can see? --- Quote End --- thank you for your help! the following is the code automatically generated from IP Catalog wizard for the 1 port RAM using M20K memory. I am wondering if I can add some extra ports/components, and add some process into the architecture part to perform some actions.
LIBRARY ieee;
USE ieee.std_logic_1164.all;
LIBRARY altera_mf;
USE altera_mf.altera_mf_components.all;
ENTITY memory IS
PORT
clock : IN STD_LOGIC := '1';
data : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
rdaddress : IN STD_LOGIC_VECTOR (6 DOWNTO 0);
wraddress : IN STD_LOGIC_VECTOR (6 DOWNTO 0);
wren : IN STD_LOGIC := '0';
q : OUT STD_LOGIC_VECTOR (31 DOWNTO 0)
END memory;
ARCHITECTURE SYN OF memory IS
SIGNAL sub_wire0 : STD_LOGIC_VECTOR (31 DOWNTO 0);
BEGIN
q <= sub_wire0(31 DOWNTO 0);
altsyncram_component : altsyncram
GENERIC MAP (
address_aclr_b => "NONE",
address_reg_b => "CLOCK0",
clock_enable_input_a => "BYPASS",
clock_enable_input_b => "BYPASS",
clock_enable_output_b => "BYPASS",
enable_ecc => "FALSE",
init_file => "initial_data.mif",
intended_device_family => "Stratix V",
lpm_type => "altsyncram",
maximum_depth => 128,
numwords_a => 128,
numwords_b => 128,
operation_mode => "DUAL_PORT",
outdata_aclr_b => "NONE",
outdata_reg_b => "UNREGISTERED",
power_up_uninitialized => "FALSE",
ram_block_type => "M20K",
read_during_write_mode_mixed_ports => "DONT_CARE",
widthad_a => 7,
widthad_b => 7,
width_a => 32,
width_b => 32,
width_byteena_a => 1
PORT MAP (
address_a => wraddress,
address_b => rdaddress,
clock0 => clock,
data_a => data,
wren_a => wren,
q_b => sub_wire0
END SYN;
