questasim unable to checkout a license
Hi ,
I am trying to install to run a questasim (RTL simulation) in quartus prime lite edition 22.1.
when I try to run the RTL simulation.
Error showing
" unable to checkout a license. Make sure your license file environment variable (e.g., LM_LICENSE_FILE) is set correctly and then run 'lmultil lmdiag' to diagnose the problem."
But I already downloaded the license from the Intel® FPGA Self-Service Licensing Center .
(I used my PC NAME , NIC ID , FIXED Type License). And set the environmental variable ( image attached ).
In quartus prime software also I license path is detected ( image attached).
I try to run the questasim directly from the location "C:\intelFPGA_lite\22.1std\questa_fse\win64".
same error is showing.
Please tell anyone where I done the mistake.
Thanks for your time
