Questa simulation hangs (nondeterministic)
As it worked fine after you changed the project, the error may related to the project and testbench. It may be that your project got stuck during simulation, causing excessive CPU resource usage.
You may check your testbench to see if there are any operations that cause an infinite loop.
- c-thaler2 years ago
Thanks for the reply.
Questa is able to detect zero delay loops, so I should see an error about this. Furthermore, most of the time the tests run just fine. I have to run a single test a few hundred times to cause this behavior. That means it is nondeterministic behavior. If there is an infinite zero delay loop I should see the hang up in every simulation run.
Besides that, I should be able to break/pause simulation in such a loop, which does not work either. - c-thaler2 years ago
I was able to reproduce with the other project, too. It took a few thousand simulation runs over the weekend. But finally it got stuck with 100% CPU load.
