DukeCityWildcat
3 years agoQuesta Intel Starter - How to get signal to display as a waveform in the Wave window
Can anyone tell me how I can get my "sum" signals to display as a waveform rather than a sequence of integer blocks? I attached the Wave window so you can see what I am talking about. I also attached...
- 3 years ago
The question isn't completely clear. Are you referring to displaying an integer signal as a waveform curve? That's done by selecting Format->Analog in the wave viewer.
FvM
3 years agoThe question isn't completely clear. Are you referring to displaying an integer signal as a waveform curve? That's done by selecting Format->Analog in the wave viewer.
- DukeCityWildcat3 years ago
Thanks, Format->Analog did the trick. Setting a good min and max value and selecting "Clamp waveform within row" gave me exactly what I was looking for!
