DukeCityWildcat
3 years agoQuesta Intel Starter - How to get signal to display as a waveform in the Wave window
Can anyone tell me how I can get my "sum" signals to display as a waveform rather than a sequence of integer blocks? I attached the Wave window so you can see what I am talking about. I also attached...
- 3 years ago
The question isn't completely clear. Are you referring to displaying an integer signal as a waveform curve? That's done by selecting Format->Analog in the wave viewer.
sstrell
3 years agoYou have sum as an integer so that's a 32-bit signal. You would need to add the 32 individual signals to the wave window or there may be an option when you right-click sum in the Wave window.
