Questa Intel Edition licensing
Hi all,
I am trying to evaluate possibility of using UVM for testing our designs. Since we are targeting Intel FPGAs I would like to use Questa Intel Edition simulator (the free simulator from Intel). However, when I try run my UVM simulation, I receive following error:
# ** Fatal: (vsim-7099) Unable to check out a verification license for the randomize() feature.4 Replies
- AR_A_Intel
Hello
Welcome to Intel forum. From what I understand, I believe the following constructs require svverification license:
· randomize
could you try this: specifying vsim -nocvg will turn off all coverage features. See how things go.
- JKast1
thank you for your answer. Yes I agree with your conclusion, that randomize requires svverification license. The main issue is how to obtain this license.
Must it be bought? If so, how much is it cost?
Is it possible to be activated for some evaluation period?
Is it even possible to use it with Intel edition of Questa?
I tried to run vsim with -nocvg parameter as you suggested but it did not help. I will try to build minimal code example to ensure that the paramer is not redefined somewhere in the build script, but I believe that it is set correctly. Also, please keep in mind, that to run UVM in any reasonable manner, I need to call randomize() during the sequence generation, so if the issue is the randomize() call, I will need the svverification license. Therefore, could you please point me somewhere or to someone who know what it is exactly and how to obtain it?
Thank you,
Jan
- AR_A_Intel
For purchase of a license.
Kindly contact your nearest Intel salesperson or distributor from link below:
https://www.intel.com/content/www/us/en/partner/where-to-buy/overview.html
- AR_A_Intel
We do not receive any response from you to the previous reply that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
