Questa Intel Edition licensing
Hello
Welcome to Intel forum. From what I understand, I believe the following constructs require svverification license:
· randomize
could you try this: specifying vsim -nocvg will turn off all coverage features. See how things go.
- JKast14 years ago
thank you for your answer. Yes I agree with your conclusion, that randomize requires svverification license. The main issue is how to obtain this license.
Must it be bought? If so, how much is it cost?
Is it possible to be activated for some evaluation period?
Is it even possible to use it with Intel edition of Questa?
I tried to run vsim with -nocvg parameter as you suggested but it did not help. I will try to build minimal code example to ensure that the paramer is not redefined somewhere in the build script, but I believe that it is set correctly. Also, please keep in mind, that to run UVM in any reasonable manner, I need to call randomize() during the sequence generation, so if the issue is the randomize() call, I will need the svverification license. Therefore, could you please point me somewhere or to someone who know what it is exactly and how to obtain it?
Thank you,
Jan
