Carlos_FPGA18's avatar
Carlos_FPGA18
Icon for New Member rankNew Member
2 hours ago
Questa FPGA Starter Edition – License file missing FEATURE/INCREMENT lines
Hello Altera Support Team,
I am a university student experiencing a license generation issue with Questa FPGA Starter Edition (SW-QUESTA).
I successfully registered in the Self-Service Licensing Center (SSLC) and generated a free Fixed Node license for my computer.
However, the generated .dat file contains only comment lines in the FEATURE section:
# FEATURE START # This is license file for Questasim*-FPGA Starter Edition # Number of seat licenses is 1 # License Expires 20-Oct-2027 # FEATURE END
There are no active FEATURE or INCREMENT lines in the license file.
When I try to launch Questa Intel FPGA Starter Edition 22.1, I receive the following error:
"Unable to checkout a license. Make sure your license file environment variable (e.g., LM_LICENSE_FILE) is set correctly."
Troubleshooting already performed:
  • Verified that the LM_LICENSE_FILE environment variable points to the correct .dat file.
  • Confirmed that Windows can locate the file.
  • Regenerated the license through SSLC using the same registered computer.
  • Verified that the newly generated license file has the same missing FEATURE/INCREMENT lines.
The license request was processed successfully, but the generated files do not contain usable license features.
Could you please confirm whether this is an issue with the SSLC license generation system and advise how I can obtain a valid Questa FPGA Starter Edition license file?
Thank you for your assistance.
1 Reply
  • ai_responder's avatar
    ai_responder
    Icon for Community Manager rankCommunity Manager
    Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
