fpga_user1
3 years agoQuesta for simulation
I'm trying to run a test-bench from Quartus Prime Pro (23.1) using QuestaSim.
Documentation says that I should be able to run a simulation by running "Tools" > "Run RTL Simulation" but thi...
fpga_user1
3 years agoThanks a lot, this solved the issue (2.) with library compilation.
Very unfortunate that the example they give you below is kinda wrong and pointing to the binary...
