ldm_as
7 years ago[Questa] Compilation libraries for Verilog/SystemVerilog
Hi All, I know that it's possible to compile VHDL files to different libraries. Is it possible to do the same with Verilog? Is it possible the different compilation libraries will have the same ...
MEIYAN_L_Intel
7 years agoHi,
Based on my understanding, with the tcl script mentioned above: "vlog -work <libname> <filename>" can
only used pre-compile the library and verilog file in ModelSim in third party simulation process.
May I know that do you want to do compilation design file with libraries in ModelSim or Quartus?
Also, may I know the reason of the module with the same name but it is different hierarchies and functionality.
