HalmonCelman
3 years agoQuesta always return X state on output
I'm on CentOS 7 and I've installed Quartus Prime Lite 21.1
I'm trying to run simple simulation in Questa.
my *.bdf file:
my *.vwf file
when i'm running Simulation>Run Fu...
- 3 years ago
I think it might be the Questa tool issue. I was using Modelsim previously.
Could you try to use Modelsim Intel FPGA edition instead of Questa and see if the issue persists?
Richard Tan
RichardT_altera
3 years agoHi,
I am able to simulate the design successfully at my side.
My guess is most likely the NOT gate is not connected to the input and output port.
Could you move the NOT gate around to see if the line still connected? You may check the RTL viewer to confirm.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
HalmonCelman
3 years agoHi,
Thank you for your response,
I tried to move gate and wires are still connected, also I have run RTL viewer, result:
HalmonCelman
