sneha_wagh
3 years agoQuery related to I2C slave IP and SDM IP
I have attached the document that seeks the information related to I2C slave component and SDM IP component integration.
Can you help us to resolve the requested queries ?
Regards.
tehjingy_Altera
3 years agoHi Sneha
You could try out using SignalTap to probe the QSPI signals.
Jingyang, Teh
sneha_wagh
3 years agoOk,
After going through the document, can you confirm below flow ?
VCS simulator pattern generator for mailbox on avalon interface -> mailbox client IP receiving the avalon signals -> SDM IP -> SDI QSPI IO pins tapped in Signal Tap Debugger -> VCS simulator analyzing the Signal Tap captured data.
Also can we use this QSPI interface i.e. AVS pins of the Flash after configuration ? Or is this interface is only meant to access the flash for configuration purpose ?
Sneha
