Query related to I2C slave IP and SDM IP
Hi Sneha
Could these document be the information that you wanted on the mail box?
Here is an example program of the mailbox.
Related to the signal description you could find them listed here in section 1.2:
Regarding simulation you could follow the steps here to generate the simulation for the mailbox IP.
https://www.intel.com/content/www/us/en/docs/programmable/683102/21-3/simulating-cores.html
If not could we have a call tomorrow instead at 10am IST?
Jingyang, Teh
Hi Jingyang,
Thanks for the information.
After going through the documents, understood the details of design. Now as of now, I have one query:
1. Lets assume that we are trying to make access to QSPI Flash with the help of Mailbox Client IP. Here, how we can test the transactions sent to mailbox client are getting converted to QSPI commands ?
I.e. If we make some Avalon transactions to avmm port of the mailbox client related to QSPI access , they will eventually will transferred to QSPI pins. How to access the QSPI pins in simulation ? As the pins are not available inside DUT to view to user.
To understand this, I would recommend a call.
Sneha
