Va3
3 years agoQuery Related to FMCA loopback
I am trying to send the data from a counter to Native PHY IP and receiving back using the FMC Loopback Card.
The TX side data is transmitting correctly but the RX side I am receiving the w...
skbeh
Contributor
3 years agoHi Sir
A suggestion would be use a simpler design to verify first then only start to take it from there.
You can download A10 NativePHY with transceiver toolkit design example at below link, targeting Arria 10 dev kit too.
https://community.intel.com/t5/FPGA-Wiki/Arria10-Transceiver-PHY-Basic-Design-Examples/ta-p/735196
This is a simple 1.25G 1 channel design with ATX PLL. You can use transceiver toolkit to perform “serial loopback” as starting point.
