Va3
3 years agoQuery Related to FMCA loopback
I am trying to send the data from a counter to Native PHY IP and receiving back using the FMC Loopback Card.
The TX side data is transmitting correctly but the RX side I am receiving the w...
skbeh
Contributor
3 years agoHi Sir
The suggestion is you can try reduce the data rate to 11.3Gbps or lower.
According to Arria 10 Device Datasheet, Table 20. Transmitter and Receiver Data Rate Performance
If VCCR_GXB = VCCT_GXB = 0.95V, maximum data rate is 11.3Gbps.
Document link: https://cdrdv2.intel.com/v1/dl/getContent/683771
