11 years ago
quatus_pgm for ARM architecture
We want to program our boards with an USB-Blaster and a RaspberryPi. For this we need quartus_pgm that runs on ARM architecture. Does this quartus_pgm flavour exist? Can we get quartus_pgm compiled for an RaspberryPi platform?
    The quartus_pgm code is only available for intel architecture. Both windows and linux are supported, but no ARM. I've not done it, but i've seen descriptions of other conifiguration methods in the configuration handbook.
    There is a work-around you can use. I once had a software co-worker test a Linux remote USB server/virtualization package that I forget the name of (sorry!) that allows you to;
    1. Plug in a USB device to a remote computer, eg., a PowerPC or ARM, and run the USB-over-Network virtualization software
    2. Run the corresponding USB-over-Network virtualization software on your x86 PC
    3. When you connect the x86 client to the USB-Blaster plugged into the ARM via the USB-over-Network server, the x86 host finds a new USB-Blaster device, and Quartus recognizes it.
    I posted these details on this forum somewhere, but I don't recall when and under what thread :)
    Found it! (A search for PowerPC turned it up)
    http://www.alteraforum.com/forum/showthread.php?t=42325
    The software I had my co-worker test was USB/IP
    http://usbip.sourceforge.net/
    and that thread also has the suggestion to use a Virtual Machine, eg., run Windows inside VirtualBox on your Pi.
    Cheers,
    Dave
