JORNLicences
5 years agoQuartus/ModelSIM FlexLM Licensing Error -5,147: No Such Feature
We rencently converted our ModelSIM licences from node locked to floating. The newly generated licence file now contains our Quartus and ModelSIM licences.
The Quartus licences appear to function ...
Nurina
5 years agoHi Paul,
Thanks for providing the items I requested. Can you perform the following checks:
- Make sure the NIC ID is from a physical NIC card, not virtual ID.
- Make sure the daemon executable paths are correctly set. From the licensing manual it should be under: "<installation-directory>\bin64\alterad.exe" which is different from your license file. Look for the daemon files in your server and set it to that.
- Is your license file saved in this path: "<drive>:\flexlm" If not, please save it there as it is the preferred location.
- Did you follow all the steps to set up floating license? Available here at section 4.3.5: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/quartus_install.pdf#...
- Could you try restarting or performing a full reboot of your server?
Remember that each time you make changes in your license file you need to restart your server.
Nurina
