16 years agoQuartusII9.1sp2 webedition for linux: no optimization for area/balanced ?
I am working with QuartusII WebEdition 9.1sp1 and 9.1sp2 under linux and windows and i figured out that there is a difference between the linux and the windows version:
When I changed the synthesis optimizations from "speed" to "area" or "balanced" the linux version does not apply these settings during synthesis, while the windows version does! Thus, whatever project I compile in the linux version with the settings turned to area or balanced, I get the same hardware resource usage and performance as for the speed option (-and during synthesis, it gives me an info-line telling me that it's going to use the speed optimization now). I also tried to set the optimization goal using tcl assignments, but this also didn't work. I had a look into the "known issues" and "release information" documents on the webpage but wasn't able to find anything regarding this issue... Could it be that there is a bug in the linux version of the webEdition or am I doing anything wrong here? Do you have any ideas of a workaround for this maybe ? Thanks for the help! Bernd.
