<Quartus_install_dir>/quartus/eda/sim_lib/synopsys is missing
- 3 years ago
It seems that Quartus Lite version only supports simulator from Mentor Graphic(siemen) only.
If you want to use a simulator other than Mentor on Linux, use Quartus Prime Standard or Pro Edition.
Richard Tan
Which OS are you using?
If you using Window 10 then it will Not show up/installed as Synopsys is only supported in Linux OS.
Reference:
https://www.intel.com/content/www/us/en/docs/programmable/683080/22-1/simulator-support.html
Richard Tan
- zayjanos3 years ago
Hi Richard,
I installed Quartus Lite 18.1 on Linux OS, but eda/sim_lib/synopsys is missing. Can you please confirm that it is expected?
Also installed Quartus Standard Edition on Windows, then Mentor and Aldec are supported.
Should I try Quartus Standard Edition on Linux to get Synopsys simulation models?Thanks,
Janos
