King22
3 years agoquartus22.4 fpll unlock
Hi All
in Quartus22.4 , I use a fpll as transceiver pll , but it can not lock , but it can lock when I use Quartus21.1 , dose any one have this problem , or what should I do , I use Quartus22.4 b...
- 3 years ago
Hi King22,
Thanks for the project file. I am able to reproduce the crash so I will make a report to engineering to fix it in future release.
As for the fpll can't unlock in Quartus 22.4, can you continue the communication in another forum that was posted by you?
I believe that was supported by another AE in that post.
I will close this one. Is it okay for you?
Aqid
AqidAyman_Altera
3 years agoHello,
- Can you share the project file with more than 4 channel for me to reproduce the Quartus crash on version 21.1?
- Thank you for the explanation. I will reproduce it from my side.
Aqid
- King223 years ago
Hi Aqid
attached project is 8 lane transceiver , I use quartus prime pro 21.1 and got crashed ,
, the same project run in quartus prime pro 22.4 will finish smoothly , (but have fpll unlock issue)
BRs
King22
