11 years agoQuartus2 - enable switch to select valid data
Hi there,
in my schematic, I use a Compare Block (still not sure, if it works correctly) to decide, if the input data is valid. Now, I`m looking for something like a switch, that catches my valid data value. So, if the compare block gets high, the valid data value should be catched or transmitted. Is there a block I can use for? Or a workaround to get this fixed? Thanks a lot. kind regards
