Quartus18.x,19.1 issue1: Programmer
- 7 years ago
I think it might be your flash is not fully erase. (the reason you not able to verify)
The Programmer Engine supposed to NOT touch other flash partition except those defined with bitstream and user data.
Kindly follow the attachment pdf for step to fully erase.
(Since you are using MAX 10, use .pof file instead of .jic)
I hope this will help.
Hi, about heaven and hells.....
.sof or .pof compiled on different version has no impact on issue. 15.0 header or 18.1 header process same way on version so:
.pof .sof versionless:+
Programmer version 18.1 Lite, 19.1 (exist just one version). doesn't work, remember this appeared from 17.x (now removed).
Programmer version 15.0 Work forever.
Programming .pof with 15.0 version
just after .pof loaded .sof with 18.1 version
.pof erase on 18.1 as written work for sure.
.pof on 18.1 version verify, programming fail after a while.
