Quartus18.x,19.1 issue1: Programmer
- 7 years ago
I think it might be your flash is not fully erase. (the reason you not able to verify)
The Programmer Engine supposed to NOT touch other flash partition except those defined with bitstream and user data.
Kindly follow the attachment pdf for step to fully erase.
(Since you are using MAX 10, use .pof file instead of .jic)
I hope this will help.
Hi RRomano001,
If you are using 19.1, there is some issue with USB Blaster II when using Quartus 19.1 version. Please follow the following KDB for workaround.
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/component/2019/why-does-my-usb-blaster-ii-not-work-when-using-intel--quartus---.html
Thanks😉
- RRomano0017 years ago
Contributor
NOPE NOPE NOPE NOOOOOOOPEEEEEEE!!!!!
PLEASE READ THOROUGH:
Your link report this issue:
USB BLASTER NOT WORKING.
THIS IS NOT NOT ****NOT**** my case!
Device drivers right are ok, Cable is working, I am using on regular basis.
USB Blaster is perfectly working as you can read from device enumerated and IN WORKING ORDER.
Programmer 19.1 fail EXACTLY SAME WAY of 18.1 and probably 17.x 18.0.
============>>>>>>>>>>>>>_____ SOFTWARE Programmer of release 15.0 work hassle FREE. _____<<<<<<===============
--->>>--- QUARTUS PROGRAMMER ---<<< <<not usb Blaster cable>>.
Issue to USB Blaster came from SOftware 18.x 19.x not from drivers.
