RRomano001
Contributor
7 years agoQuartus18.x issue3: if elsif errant
Hi, reported and disappeared issue was back again: Quartus Prime Version 18.1.0 Build 625 09/12/2018 SJ Lite Edition Linux Mint 17.3 Sony vaio SVS1511C5E Target 10M04SCE144A7G first issue link...
KhaiChein_Y_Intel
7 years agoHi Roberto,
Just to clarify, is this Intel FPGA Mac IP or hand coded by you ? What tool you were using in the above waveform? Can you use the ModelSim to check the behavior of the above snipped code?
Or
Can you attach the testbench(.vhd) that can run on the above sample code?
