RRomano001
Contributor
7 years agoQuartus18.x issue2: lost path to files on project reopen.
Platform Linux mint 17.3 I7 Sony Vaio 12GB ram. Project when reopen lost file link with an error file not found. File is still at same position on myIP folder. same if file is open on a non proj...
KhaiChein_Y_Intel
7 years agoHi Roberto,
Do you mean that this error occurs when more than one instance are opened and giving root access solves the problem?
In the screenshot provided, the path in the error message is /Project/Altera/Cheap_Ethernet_MAX10/Avalon_Master_Sequencer_v0_5.vhd. The exact location of this file is /Project/Altera/my_Core/AvalonSequencer, which is different from the path stated in the error message. Can you remove the file in the software and add the file from the correct location?
