RRomano001
Contributor
7 years agoQuartus18.x issue2: lost path to files on project reopen.
Platform Linux mint 17.3 I7 Sony Vaio 12GB ram. Project when reopen lost file link with an error file not found. File is still at same position on myIP folder. same if file is open on a non proj...
KhaiChein_Y_Intel
7 years agoHi,
Can you open the same file when only one Quartus instance is opened?
RRomano001
Contributor
7 years agoI found opening two instance caused some trouble.
I probably launched as root to check if programmer issue was related to some access right.
Launching as root from user file on ~.altera.sbt4e get owned by root privilege.
Restoring access to group and user cleaned up some issue on settings save restore.
File opened on path different from design folder report this.
Ex: File where opened from IP cores folders or synthesis, or output as reported, never open back.
Roberto
