11 years agoIn my case I have Windows 7 Ultimate running on a VM in an iMac. I had installed the latest 2013 32 and 64 bit, but for some reason that did not help. I removed them with the control panel / uninstall program, then I went back and did both the 32-bit and 64-bit for 2010. Comes right up now. So just FYI you may have to fiddle with things to get the right combination. Incidentally, if I run version 13 in a VM with an old copy of XP it is faster than version 14 in a VM running 7. So if you're in the same boat that I am you could just do with version 13.
